FIRST Robotics Competition Discussions
Numeric integration
Am I doing this right? I have set up a collector on an analog signal to get 3 points I feed this into the Simpsons Rule integration. Is the dt in the integration vi in seconds or milliseconds? That is if I have my capture loop running every 100ms is dt 100 or .1?
(6,144 Views)
Your answer will be in terms of whichever units of dt you use.
(2,875 Views)
