FIRST Robotics Competition Discussions
Network Variable
I know there's a way to create a variable on one system, like the dashboard, and read it on the other, like the robot.
Is that the "shared varaiable"? is there an example of how to set up the networked variable? or a tutorial? a link to some kind of information on how to pass data through a variable.
"Lockheed" Joe
Testing Blog"
(5,121 Views)
I'm pretty sure the FRC framework uses TCP (or maybe UDP) for all communication.  I don't know if the FRC installation includes the Shared Variable Engine, and it adds some overhead so you might not want to use it even if it is available.  However, if you're curious, here's the "Using the LabVIEW Shared Variable" document.
If you want to send data from your dashboard to the robot, and if the rules allow it, in my opinion the easiest approach is to set up a separate loop in your robot code that listens for UDP packets and writes the data received to a global variable.  You could also do this with TCP, but UDP requires less work (at the very slight risk of some packet loss).  Since you're dealing with fixed IP addresses and only a single connection (between the dashboard and the robot) the networking code is pretty simple for either protocol.
On your dashboard, start by opening a UDP socket using UDP Open (Data Communication->Protocols->UDP) outside the main loop.  You can set the port number to 0 to get a random port.  Inside the loop, take the data you want to send, run it through "Flatten To String" (Numeric -> Data Manipulation palette), then connect that string to UDP Write.  Set the IP address to the address of your robot and pick a port number that you will also use in your robot code.  When the main dashboard loop ends, close the UDP socket with UDP close.
In the robot code, open a UDP socket, but pick a specific port number (greater than 1024).  Add a new while loop and put a UDP Read inside of it.  Take the string output and connect it to Unflatten From String.  You will also need to wire a constant of whatever type of data you expect to receive so that Unflatten knows how to interpret the string.  Then, connect the output to a new global variable, which you can then read elsewhere in your code.
A couple of details: you'll want to check that neither UDP Read nor Unflatten From String returns an error before updating the global variable.  You should also find a way to close the UDP socket when your loop completes.  One easy approach is to set a timeout of -1 for UDP Read (wait forever).  Wire the error output to the stop terminal in the while loop.  Then, wire the UDP connection ID through your main loop as well, and close the UDP socket when the main loop completes.  Then, when the socket is closed, UDP Read returns an error and the reading loop terminates.  If you're really paranoid, you'll check that the data received comes from your dashboard, and not from someone else's.  If Windows Firewall is running, it might ask you about allowing through your UDP traffic.
If you're going to take this approach, take a look at the UDP Sender and UDP Receiver examples.
(3,076 Views)
Thanks for the information, I'll check the rules and then look at the TCP/UDP stuff. We were wanting to send timing/spacing parameters based on field configuration a start time. This would be a hassle to talk to team mates to figure out field configuration, set variables in the code, then re-deploy.
"Lockheed" Joe
Testing Blog"
(3,076 Views)
The FRC image does not include the shared variable engine.
Joe, there are many ways to skin a cat. You could put switches on the robot connected to the DIO on the digital sidecar to set your options. You could put switches on the driver station connected to the cypress PSOC and do the same thing. If you aren't using the PSOC, you could use the virtual I/O on the DS to do the same thing. You could use joystick buttons to increment/decrement a variable on the robot. Those are all common ways that FIRST teams set autonomous parameters.
(3,076 Views)
