FIRST Robotics Competition Discussions
Motors programming problem
Hello!
I programmed my 3rd motor for my robotic's arm but all I can do with a button on my Logitech Attack 3 joystick is to make it function one way. I want to be able to program it to use another button to reverse the motion.
Thank you!
(5,247 Views)
Hey,
You should be able to just get multiple buttons out of the joystick (using an unbundle by name block).
I posted two screenshots showing the general idea of how this could be used. Post back if you have any questions.
Kevin Fort
Principal Software Engineer
NI
(4,103 Views)
Yes! Know the only problem is , how do I use Button1 to make my motor go forward and Button 2 to make it go backwards? I tried to put button 2 with an output of a negatif DBL but doesn't work...
(4,103 Views)
You should be able to set it such that button 2 causes your third motor to have an output set to a negative number between 0 and -1 with -1 being full reverse. What is not working when you use a negative double?
Kevin Fort
NI
(4,103 Views)
It working now, the problem came from the DB37 Ribbon Cable. I folowed the instructions from DB37 Ribbon Cable Assembly - Rework Instructions.
Thank you for your help.
(4,103 Views)
