The FIRST Robotics Competition (FRC) projects are sets of VIs, organized in a LabVIEW project, that you can use as a template when building a robotics application. The FRC projects consist of two project template types. Use the FRC robot project templates to develop the program you want to deploy to and run on the roboRIO. Use the FRC Dashboard Project template to develop a program that allows you to view data on the host computer.
This tutorial describes how to create, modify, and deploy a robot project, also referred to as an FRC robot project, to the roboRIO. In this tutorial, you develop a program to perform arcade driving with a joystick and Talon motor controllers.
Creating an FRC Robot Project
Complete the following steps to create an FRC robot project.
LabVIEW displays the new FRC robot project in the Project Explorer window, shown as follows.
Notice that the FRC robot project contains two targets: My Computer and Target (roboRIO-1959-FRC.local). Files under My Computer are those you want to use and run on the host computer. Files under the roboRIO Target are those you want to deploy to and run on the roboRIO.
The roboRIO Target contains one top-level VI, the Robot Main VI, which is the master VI for the robot and is the top-level VI for the robotics program you run on the roboRIO. This target also contains a Team Code folder. This folder contains VIs that the Robot Main VI calls.
Note The project that you create also contains default code to drive a robot in Teleop mode. The default code assumes the robot includes two motors and one joystick. |
Refer to Tutorial 5—Editing Team Code VIs for more information about the subVIs the FRC Robot Project contains.
Deploying the FRC Robot Project to the roboRIO
After you develop the FRC robot project you want to run, you must deploy the program to the roboRIO. You can deploy the program in three ways: using the Run button; from the Project Explorer window; or as a stand-alone, built application.
Note Regardless of how you deploy your robot program, you must also be running the FRC Driver Station in order for output (motors etc.) to work. The FRC Driver Station can be launched from the Start menu or from the Desktop shortcut. |
Deploying the Program Using the Run Button
When you deploy a program with the Run button, you maintain a connection between the host computer and the roboRIO. The program runs on the roboRIO, but you can manipulate the front panel objects of the program from the host computer. You therefore can deploy a program with the Run button to perform live front panel debugging.
Complete the following steps to run the FRC robot project and perform live front panel debugging.
If you click the Run button of the Robot Main VI and it runs slowly, close any subVIs of the Robot Main VI that are open on the host computer to improve performance. Do not close the Robot Main VI.
Note If a program is running on the roboRIO and you redeploy that program with the Run button, the roboRIO stops and restarts the program you deployed. LabVIEW redeploys any VIs that changed or are no longer in memory on the roboRIO. |
Deploying the Program from the Project Explorer Window
In the Project Explorer window, right-click the Robot Main VI and select Deploy from the shortcut menu to deploy the VI and any support files for the VI to the target. When you deploy a program from the Project Explorer window, the program runs only on the roboRIO to which it was deployed. Therefore, you cannot perform live front panel debugging.
Building and Deploying a Stand-Alone Application
To run a robot in competition, you must build the FRC robot project into a stand-alone application that you deploy to the roboRIO. You then can specify the application to run at startup so the application runs as soon as the roboRIO is powered on.
Complete the following steps to build the FRC robot project into a stand-alone application and run it on the roboRIO at startup.
Connecting to the roboRIO
If you stop the VI or close the front panel, the VIs are no longer running on the roboRIO. However, if you only disconnect from the roboRIO, the front panel on the host computer appears to stop, but the VI continues running on the roboRIO. Right-click the Target (roboRIO-1959-FRC.local) item in the Project Explorer window and select Disconnect from the shortcut menu to disconnect from the roboRIO. If you then close the front panel and reconnect to the roboRIO, you re-access the front panels in memory on the device. The front panel of the running VI reappears and displays the current state of the VI. Right-click the Target (roboRIO-1959-FRC.local) item in the Project Explorer window and select Connect from the shortcut menu to connect to the roboRIO. You cannot access the front panels of VIs in memory on a roboRIO if a built application is running. You first must stop the running built application or cancel the Connect operation.
