FIRST Robotics Competition Discussions
LINX PI3 wifi
I am trying to connect pi3 wifi with labview(using LINX). If I Connect it losses once I remove the ethernet. how to use pi3 on mobile robot with LINX. Any ideas?
Bharath
Thanks & Regards,
Bharath Kumar
GCentral
(2,899 Views)
These forums are specifically meant for teams competing in the FIRST Robotics Competition (FRC).
You'll likely want to try these forums: https://forums.ni.com/t5/LabVIEW/bd-p/170  They are the general LabVIEW forums.
If you are in fact working with a FRC team, I'd encourage you to look at R69 before continuing down your current path.  It'll only lead to heartache otherwise.
(2,882 Views)
