FIRST Robotics Competition Discussions
FTC Questions (Bluetooth, All-In-One program, and Program Chooser)
The FTC Getting Started PDF that is installed with the FTC software includes documentation on Program Chooser.
When you select a program on your NXT to run in dual-program mode with Program Chooser, that means that the Controller Station/Field Management System will kill whatever program is running on your NXT (if any) and run the program you selected when the match mode changes from Autonomous to Tele-Operated.  Program Chooser will not cause anything to be put onto the NXT - it only allows you to select from programs that are already there.  Teams are always expected to manually run their own autonomous program and use the Enabled/Disabled flag to control when the robot actually starts moving.
Ramsey Nasir
Senior Software Engineer, InsightCM R&D
Message 11 of 11
(858 Views)
