FIRST Robotics Competition Discussions
Error Building code for cRio after update
When I try to build the code to be downloaded into the cRio (to be run at start up) I get the error listed below. I went back to an older version that had been build and deployed, that got the same error. Since I didn't even realize I was using a "AB_Build.lvclass".
My question, what is the AB_Build class?
What objects are built from it in the Robot project?
What could be the problem or what I can look at to fix this?
ERROR TEXT:
An error occurred while saving the following file:
C:\Documents and Settings\Joe\My Documents\LabVIEW Data\2010 Game Robot Project_02_20_10\Robot Main.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>
"Lockheed" Joe
Testing Blog"
(4,101 Views)
I'm wondering if you are trying to build code you originally developed using last year's template?  If so, look in your autonomous code to see if you have a constant Boolean (T/F) wired to a case structure.  If you do, replace the constant with a control, and then try to build your code.
(3,069 Views)
I'm using this years template but we usually have expirimental code with a t/f constant wired, depending on who's trying something. I'll see if that fixes it when I get back to the crio.
Thanks!
"Lockheed" Joe
Testing Blog"
(3,069 Views)
That worked! thanks!
"Lockheed" Joe
Testing Blog"
(3,069 Views)
