FIRST Robotics Competition Discussions
Double solenoid
We are attempting to program a double solenoid. Right now we have it that pressing one joystick button extends the cylinder and pressing another joystick button retracts the cylinder. We would prefer that one button press extends the cylinder then pressing the same button a second time retracts the cylinder. Is this possible?
(5,316 Views)
Accepted by topic author andivwh
That is completely do-able. The way I would do it is download the Memory Library from FRCLabVIEWTutorials.com (https://www.frclabviewtutorials.com/tutorials/memory-library/) and use the button-on-button-off configuration for using both the edge detector and SR Flip Flop (the contents of the library) like this:
(other example on the page).
Team358, also publishes examples of doing this with a feedback node. (http://www.team358.org/files/programming/ControlSystem2015-2019/labview/index.php#ButtonToggleAction)
Personally I prefer the abstraction of the memory library.
(5,306 Views)
Here is the simplest way that I know of to create a toggle output.
Champion CLA
Making senseless computers do
intelligent real world things
is NOT easy. SO MAKE IT FUN!
(5,291 Views)
Thanks for the help. We have it working now.
(5,259 Views)
We are using this snippet and it works great, so of course now they want more. We actually have this snippet twice for two separate solenoids. Is it possible to have 1 button (4) to activate both solenoids then two separate buttons (5) and (6) to deactivate the solenoids at separate times.
(5,131 Views)
Yes, this is a use case where the SR Flip Flop is really useful. Something like this should work:multiButtonExample.png
Basically, while the "on button" is pressed, the flip flops are set to True (Set) causing the solenoids to go forward,
but turning off (Resetting) each of their flip flops (and solenoids) is left two additional buttons.
For this example, I opted to set the Enable to true when exactly one of the two inputs are true.
If I were to tie it always true, then pressing both the "on button" and the corresponding "off button" would toggle the output (every time the vi runs until the state is changed). You could use edge detectors to make is such that your driver could still be holding the on button and start pressing the off button and have it work anyways, or you could setup the toggle, or whatever (up to you).
(5,129 Views)
