FIRST Robotics Competition Discussions
Camera Problem
I recieved the error code of 44003.   "ERROR <Code> -44003 occurred at Camera.lvlib:Issue HTTP Request with Authentication.vi>>Camera.lvlib:Issue Get.vi>>Camera.lvlib:Set Image Appearance Property.vi>>Camera.lvlib:Set Enum Appearance Property.vi>>Camera.lvlib:Set Image Size.vi>>Vision Processing.vi>>Robot Main.vi
<time>01:05:01  02/17/2010
FRC: Operation failed due to a communication failure with the camera.
Any help would be wonderful. I have made a static ip and made all the necssary logins but no picture at all shows up on my netbook. just the bottom panel appears.
(5,740 Views)
It looks like this error is coming from the Robot Main.vi, is that correct? Does the image appear in the driver station dashboard OK? Can you post screenshots of your configurations for the camera so that we can ensure correct settings? Can you ping the camera at the IP address you specified? Is the IP address correct in the Begin.vi? Have you attempted all the troubleshooting steps that are list in this post?
Joshua B.
NI FIRST Support
Joshua B.
(3,110 Views)
The dashboard does not appear. I can login into the website when its plug directly into the router. I did the setup for the logins and stuff. I will post screenshots later on. Is there anything I have to set up in the robotmain.vi? The driver station loads just not the dashboard part and when i load it manually on the other pc it doesnt show the image. Any ideas? And I believe that the ip is correct in the begin.vi
(3,110 Views)
You should try searching the forums for your error issue before posting a completely new question, this issue was explained in my topic, http://decibel.ni.com/content/message/13722#13722.
To save you the trouble I'll just reiterate the solution, the camera does not have the correct login credentials. Manually make an FRC account with the password FRC. It fixed my -44003 error; let me know if it fixes yours.
(3,110 Views)
