Some data transmission protocols, such as VITA49, require that each data packet contain only samples from one channel. However, many multi-channel FPGA IP components process data in an interleaved manner. This motivates the development of a component that is capable of receiving interleaved multi-channel data and transmitting packetized data. Due to its high throughput and large capacity, dynamic random access memory (DRAM) is used to solve this problem.
Any NI FPGA target that includes a 512-bit DRAM interface is supported. This includes, but is not limited to the following targets:
| Slice Registers | 18,000 (3.5%) |
| Luts | 18,000 (7.1%) |
| BRAMs | 43 (5.4%) |
| DSP48E1s | 0 (0.0%) |
Thank you for the IP. Is there a way for you to modify the IP to map to 256 bits memory DRMA like USRP-RIO ?
GuillaumeB
There is a DRAM API that supports 256-bit width. See: <LabVIEW>\instr.lib\FlexRIO\DRAM FIFO\v2\FPGA\DRAM FIFO
