Examples and IP for Software-Designed Instruments and NI FlexRIO
Lock-In Amplifier Reference Example for FlexRIO
The NI Lock-In Amplifier Reference Example package provides FPGA, Real-Time, and Host example code that implements a lock-in amplifier on NI FlexRIO targets. A lock-in amplifier extracts a signal with a known carrier wave from a noisy environment through phase-sensitive detction. For a more detailed description, visit the Wikipedia page.
This example instantiates 4 FPGA-based lock-in amplifiers using the NI 5783 FlexRIO Adapter Module. Each 16-bit, 100 MSPS lock-in path provides 40 MHz of bandwidth. Additionally, 4 16-bit, 200 MSPS analog output channels provide precise reference tones. Two of the lock-in amplifier analog inputs may be repurposed as PLLs for external reference signals.
Latest Version
NI Lock-In Amplifier Reference Example 1.0.0.7
Software Requirements
LabVIEW 2015 and
LabVIEW 2015 FPGA Module and
NI-FlexRIO 15.5
Hardware Requirements
PXIe-7976R + 5783 FlexRIO Adapter Module or
NI 7935R + 5783 FlexRIO Adapter Module
Comments
S.Minami
NI Employee (retired)
on
I am Shigeru Minami from NI Japan.
I have some questions about this LIA reference example.
Please let me know the details.
1. I guess that this LIA reference example is for "single phase" lock in amplifier.
Because I can get only amplitude, but not phase.
However, this example has 8 DMA resources for "I" x 4ch and "Q" x 4ch.
In the near future, do you have a plan to modify this example to "dual phase" lock in amplifier?
If it is easy, I want to modify it.
Please advise me.
2. This example is for NI 5783.
And, I want higher sampling rate, for example 250MS/s or more.
If possible, I choose some high speed FlexRIO adapter modules, NI 5782: 250MS/s 2AIs or NI 5761: 250MS/s 4AIs.
So, I tried to use this sample with NI 5782.
As result, this sample works fine under 125MS/s sampling rate: Multi-Sample CLIP.
However, under 250MS/s sampling rate: Single-Sample CLIP, can not compile FPGA code.
I guess that PLL (Hilbert).vi is huge for 250MS/s because of timing violation information.
Is it possible to modify this example for 250MS/s or more sampling rate?
3. In the near future, do you have a plan to support Reconfigurable Oscilloscopes, for example, PXIe-5171R?
Almost FlexRIO adapter modules has single and narrow range of voltage.
However, PXIe-5171R has some ranges, some customers want to use it.
4. What is "Result"?
With 2 FGEN boards and TClk synchronization program, outputs 2 signals: measurement signal and reference signal.
Please see the following images.
<Lock-in 1MHz and 100mV signal.>
Result is 192mV.
<Lock-in 2MHz and 200mV signal.>
Result is 383mV.
 <Lock-in 5MHz and 50mV signal.>
 Result is 96mV.
At first, I think that this issue is linked to the following KB.
http://digital.ni.com/public.nsf/allkb/E6FCA8226A164202862572110046E717?OpenDocument
However, input impedance of NI 5782 and NI 5783 is 50 ohm.
Of course, output impedance of NI 5442 is 50 ohm.
So, I have no idea.
Why does amplitude twice?
Is "Result" Voltage peak to peak?
Please let me know.
Thank you for your time and help,
Shigeru Minami
Oduor
Member
Member
on
I have been trying to access this reference example without success.
Is it still available?
Contributors
