I have edited the Channel Emulation example (http://www.ni.com/example/31556/en/)
for the 5644R to make it usable with the 5645R
I changed the relevant settings, and then compiled a new bitfile, that can be used with the different card.
Unfortunately I don't have the equipment here to test it, but I have been told that it works fine.
The same requirements as listed for http://www.ni.com/example/31556/en/ except with the 5645R.
1. Find the example, and place the bitfile in the folder called FPGA Bitfiles.
2. Then open the project, and open MIMO Channel Emulator Host.vi.
3. Open the block diagram, and change the string constant on the left to point towards the new bitfile which I have sent you.
Thanks for our efforts. I have 5646R. Can you please guide how this example can be modified to run on it?
Thanks for making it work for 5645R. I haven't tried it yet, but it is on my list to do.
