Overview
This example demonstrates how to reconnect Network Streams using a simple State Machine Architecture.
Description
Here is a brief description of the example:
This example was created based on the Simple Network Streams found in the NI Example Finder. We utilized a state machine on the Reconnect Network Streams - Target program. This allows the program to properly close the Network Stream when it gets disconnected from the host (stopping the host VI). Then the program moves into waiting for reestablishing a connection with the host.
Requirements
VI Snippet
The Host VI:
The Target VI:
Just what I am looking for!
Unfortunately I am not able to run it because I use LabVIEW 2013 (the project was saved in LV2014).
Could you please make it available for LabVIEW 2013?
