Example Programs
Programmatically Change IP Address Of Remote System
Overview
This example shows how to programmatically change the IP address of a remote system。
Description
This code shows how to programmatically change the IP address of a remote system.
To implement this function, firstly get FTP file where host is the original IP address and remote path is the file ni-rt.ini that needs to be changed and open the .ini file. Then read the whole file, looking for "IP address =" in the file and looking for "S" (which is the start of the next item in the file i.e Subnet..). Everything in between these is the IP Address that we are interested in. Next add the new IP address into the file, replace /open the file with the same path and wirte the new content. Lastly copy .ini file on local machine and reboot the machine for changes to take effect.
Requirements
  • LabVIEW 2012 (or compatible)
  • Real Time Module 2012 (or compatible)
  1. Obtain the current IP address by doing an ftp://"ip address"/ from the .ini file and save it somewhere
    on your PC
  2. Use the LabVIEW program to set the path of the .ini file
  3. Set the new IP address on the front panel
VI Snippet
Shalini B
National Instruments UK & Ireland
