Overview
This VI demonstrates how to monitor PXIe chassis temperatures, fan speeds, and voltage rails. It can be easily adapted or expanded to include other heath information like CPU Usage.
Description
Here is a brief description of the example:
The attached VI uses the System Configuration API to get a reference to a local or remote PXIe chassis and use that reference to periodically report the chassis' temperatures, fan speeds, and voltage rails. These values are the same ones that are reported in MAX under the "Settings" tab of the PXIe chassis.
Requirements
VI Snippet
FYI, if you use this code with a 1075 or 1082 chassis and note that your system shuts off unexpectedly, you may be running into a known issue with those chassis. The patch can be found here: http://digital.ni.com/public.nsf/allkb/95D99BA0EAB4EA8B86257A6B0058BD76
Hope you people are fine. Anybody, guide me about how can I start learning National Instrument PXIe 1082. I need to analyze signals. Plus send me tutorials if you have any links. It is urgent.
comsats8@gmail.com
Is there a LabWindows CVI version of this example that I can refer to.
Thank you,
Kaizen
