Example Code
NI-RFSG: FM Radio Transmitter
Products and Environment
    Hardware
  • PXI|VXI
  • RF|Wireless
    Software
  • LabVIEW
Code and Documents
Overview
This example will take a .wav audio file, modulate it into an FM waveform, and transmit the signal using NI-RFSG.
Description
Use this example in conjunction with the NI-RFSA: FM Radio Reciever (also in the community) to experiment with sending and recieving FM radio signals using any of our hardware that implements RFSA/RFSG. The RFSG FM Tx.vi, attached here uses the Sound Files palette to open a .wav sound file and modulate it into an FM signal. This signal is then used to determine the I/Q rate for generation on the RFSG. Finally, the FM waveform is resampled with respect to the new I/Q rate, and written to the RFSG hardware for generation.
Requirements
1. LabVIEW 2015 (or compatible)
2. NI-RFSG
3. NI Analog Signal Generator compatible with Arbitrary Waveform generation mode.
1. Open the "FM Radio Transmitter LV2015 - NIVerified.vi"
2. Choose a valid RFSG resource on the front panel.
3. Set the desired broadcast frequency, power level, and sound volume (the default multiplier for volume is 1, this may need to be higher if no sound can be heard on the receiving end.)
4. Run the VI and select a sound file to be transmitted
5. Press the Stop button when finished transmitting
Comments
beloza
Member
Member
on
Здравствуйте!!!
Я всегда, как эту ошибку "niRFSG Initialize.vi .Device идентификатор является недействительным"
как это исправить
Titanium
Member
Member
on
Is there an equivalent program in LabVIEW Communications? Are the Sound VIs available?
