Example Code
MAX Technical Support Report Comparison using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Applications Engineers asks for a MAX Report all the time to help you with your issues as it reveals a lot of various information about one's system. To be able to manipulate and extract information from these files is always helpful for the troubleshooting process.
Description
By inserting the MAX Report ZIP file, you will be able to see the Running, Disabled and Stopped services for the corresponding system. You also have the functionality of comparing two MAX Report's list of running, disabled and stopped services and also the software on each system. This is very useful for troubleshooting between a working and a non-working PC.
Requirements
Software:
  1. LabVIEW 2012(or compatible)
  1. Open "MAX Report Viewer Services.vi"
  2. Enter a MAX Tech Support Report ZIP file into the top file path control.
  3. (Optional) If you would like to compare the list of services and software, enter in another MAX Technical Support Report ZIP file and ensure the Compare button is set to TRUE before running the code. If you don't want to compare anything, deselect the Compare button. (It is TRUE by default)
  4. Run the code, and the Computer name, Operating System, 32/64-bit information should be extracted from the report and displayed in the corresponding indicators.
VI Block Diagram
Jinfone
