Overview
This example inserts data into a database from an array in LabVIEW using the Database Connectivity Toolkit.
Description
When writing data to a database, you may have the data in array format, with each array element corresponding to a different column of the database. This example allows to easily write array data to your database: each array element will be written to a different column in a desired database table.
Requirements
VI Block Diagram
i do it but it shows error..no of coloumns does not equals to parameter .what does it means![]()
Perhaps you should see if the number of columns you're inserting is equal to the number of parameters you're inserting.
