Example Code
Determine if a Point is Located Inside a Triangle in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI calculates whether a specified point lies in the triangle defined by three points.
Description
This VI will take three points describing a triangle on a cartesian plane and determine if a point is located inside that triangle or not.
Requirements
  • LabVIEW 2013 (or compatible).
  1. Unzip the attached zip file
  2. Open the project and open checkTriangle.vi
  3. Enter the points describing your triangle and the point you wish to check.
-Jim B
Applications Engineer, National Instruments
CLD, CTD
