Example Code
Delete Portion Of Waveform
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This vi show  acquired data is in waveform datatype and also can to remove some of the data points.
Description
The Waveform data type is a cluster of 3 components: t0, dt and Y. User can unbundle it to pull out the Y component, namely the actual data points and perform an array manipulation on the array of DBL. Afterwords user can rebuild the waveform.
Requirements
  • LabVIEW 2012 (or compatible)
1.Insert length and index
2.Run the program, this VI will show original waveform and a certain lenght and index waveform.
VI Block Diagram
