Example Code
Convert 0xXX Hex Data to a U8 Byte Array
Code and Documents
Overview
This example VI Convert 0xXX hex data to a U8 byte array.
Description
Often hex data will be represented in the format 0xXX, 0xYY, 0xZZ etc. In LabVIEW it is best converted to a byte array for manipulation. The easiest way is to cut the hex data into a string control and use regular expression pattern matching to extract the bytes.
As each byte is extracted the loop will build the data into an array at the output tunnel. Once the entire string has been scanned a position of -1 is output, stopping the loop. Once the loop is stopped, the U8 byte array is released.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached file to your computer
  2. Open the VI " 0xXX hex data to u8 array 2012 NIVerified.vi"
  3. Run the program
VI Snippet
Stephen C
