Example Code
Basic Real-Time Network Communication Using Shared Variables
Products and Environment
    Software
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Description
Overview
This example demonstrates how to use shared network variables communication between host PC and real-time target device.
Description
This example project demonstrates the most basic version of network communication between a host PC and an RT target device. After adding the target to the project, right-click on the target and select New>>Variable. Then name the variable and enable the RT FIFO (for an in depth understanding of how shared varibles operate and their different options read Using the LabVIEW Shared Variable). Now that the shared variable has been created you can simply drag and drop the variable onto the block diagrams of VIs in the project.
In this project automatic deployment of the shared variables is disabled (right-click on the target and select Disable Autodeploy Variables), so that the host can be started and stopped without interupting the target VI. For a more complete example project open LabVIEW's  Example Finder and browse to Toolkits and Modules>>Real-Time>>Network Communication>>RT Network Communication.lvproj.
Requirements
 Software
  • LabVIEW Full or Professional Development System 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • NI Real-Time target (e.g. 9024 or compatible) with installed Network Variable Engine 12.0 (or compatible)
  1. Download and extract the attached file "Basic Network Communication LV2012 NIVerified.zip"
  2. Open project file and follow the instructions in Front Panel and Block Diagram of both VIs and run the program.
Host VI:
Target VI:
Note: Even if the same timing value is used for both VIs (target and host) you can miss some values when reading (host) loop runs to slow because of some other
processes running in parallel and decreasing performance. Also some values can be read twice if reading (host) loop is running slightly faster than writing (target) loop.
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Justin Parker
Product Support Engineer
Comments
rvillarr
Member
Member
on
Do you have this in 8.2.1 version?
Rulee
