Example Code
Basic MODBUS TCP/IP Read Holding Register using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
SImple Vi to read a given value from a TCP/IP device using MODBUS protocol
Description
The Vi opens a TCP master and reads a specified holding register, returning the value of that register.
  1. Enter IP address of device
  2. Enter Starting address (no need to enter the code of 4 for the holding register.  Just enter the last digits of the address-1
  3. Enter amount (1)
  4. Enter 0 to achieve the first register value.
Requirements
Software
  1. LabVIEW 2014(or compatible)
Hardware
  1. TCP/IP Device
Comments
WinterRain
Member
Member
on
can you send the whole vi?
justgene
Member
Member
on
Hi
I have been searching for material, (explanations, examples etc.) to create a vi that will read and control a plc from a remote location. By this I mean that a plc controlled device that uses an HMI for operator input, located at one location but monitored and controlled by a VI using Modbus TCP from a remote location, for the purpose of recording data and even simple commands such as run, stop, and standby.
I'm using LV 2014.(32 bit), I've added NI Modbus Lib 1.2.1.42 (only after updating my JKI Package Manager to 2019!).
This example is great but I am looking for more understanding behind the Modbus master/slave functions and how to use networked shared variables to create a data file for evaluation and data reduction.
So if anyone can share a tutorial or recommend an appropriate knowledge base article etc I would be very happy to dive into  it
Gene
