Overview
AGCfxp.vi applies an adaptive gain to a point-by-point signal. The goal is to condition a signal that unpredictably changes power (fades, or sees some other form of interference) such that further processing is done on a relatively consistently powered signal.
Description
This VI can be used directly after reading from an analog input. Below is a graph of a white noise signal (white) that abruptly decreases in average power, and the output from the AGCfxp.vi (output is red, gain is green). This VI shows statistically what is happening, as well as how the ds and mu input parameters effect the behavior of the output signal. Also, see the contact help of AGCfxp.vi for more information on the inputs and outputs.
Requirements
VI Block Diagram
