Example Code
Task manager in Labview
Code and Documents
This is a Labview implementation of a task manager like application. View the processes, select one to view CPU load and memory consumption. A new feature is the memory deallocation control, just in case the process start consuming to much memory.
Open the TaskManager.vi, start viewing the processes and their parameters. Select one process and view the CPU load and memory consumption. Look in the subVI for other things that are not in the Front Panels (like, total times, idle time, etc.)
Comments
jcluttrell
Member
Member
on
LabVIEW Performance course requires using Task Manager a lot. This is not possible on the remote computers through the LogMeIn account. At least for the last exercise, 4-4 this was of help. I did not have this VI available for the previous examples in the course.
instrumento
Active Participant
Active Participant
on
Includes three DLLs, two of which, psapi.dll and wtsapi.dll, seem to be Windows standard DLLs, and one, processHandles.dll, which seem to be custom and 32 bits only, thus this example won't load on a 64 bit LabVIEW.
davtrs
Member
Member
on
Hi all,
Recently I have had the problem that when I use the processHandles.dll LabVIEW crashes on some computers. Sometimes I get the error message "Access violation", which indicates a memory problem or lack of access to it, e.g. due to restricted PC rights?
Has anyone already had similar problems?
larserike
Member
Member
on
 Hi, similarly to davtrs I encountered the same crash after calling processHandles.dll (with labview 2021 - 32 bit).
Contributors
