Example Code
Read of Shift Register using NI-845x Scripted SPI API
Code and Documents
Introduction
This simple VI uses an NI USB-8451 to read SPI bytes from a shift register with an active high chip select.
The clock idles high, when not transferring bits.
For connection information see the 8451 manual.
An array is returned containing the data in bytes.
Steps to Complete
See the comments in the VI.
Mark M.
National Instruments UK & Ireland
Contributors
