Example Code
(Generic) sort algorithms for LabVIEW
Code and Documents
Here are a bunch of sort algorithms for LabVIEW. Included are:
  • Bubblesort
  • Heapsort
  • Insertionsort
  • Mergesort
  • Quicksort
  • Selectionsort
They work with classes so they are a 'bit' generic. So for example you have a array of a certain class called A. Then you have to implement a "less then" comparator. Do not forget that the < operator you will create must be a strict total order, http://en.wikipedia.org/wiki/Total_order#Strict_total_order, otherwise you may see strange behavoir. You will then pass the less operator to the sort function as strict VI reference.
Examples are included in the example folder.
Explanation on a strict total order relation. A relation is called strict total order, with relation the "less then" operator is meant, if the following holds
  • Irreflexive, for all x in a certain domain it does not hold that x < x is true
  • Transitive, for all x, y and z in a certain domain it follows that x < y and y < z implies x < z.
  • Trichotomy, for all x and y in a certain domain it follows that only one of the following holds, x < y or y < x or x = y
  • Strictly antisymmetric, for all x and y in a certain domain it does not hold both x < y and y < x are true.
Comments
geirove
Member
Member
on
Possible to Convert these to LabView 2010 or older?
Geir Ove
Contributors
