Example Program Drafts
APT Image from weather satellite decoder
Author(s): CAILLOT Antoine
NI Product(s) Used: LabVIEW 2018
Industry: Telecommunication
APT Signals
APT signal is an analogically method to transmit images. It is used by some satellites which are pretty often used by radio amateur such as NOAA 15, 18 and 19. The main challenge to build this program was to find documentation to understand how to decode APT signals. (All the documentation I found on google is in the zip file).
Application Description
The program is extremely simple, you just have to use an audio wav file  (recorded at 11025 sample/s if possible) and to press the button "Decode". Processing time might last several seconds or even several minute (depending on you computer and the file length). I included a wav file in the folder as example (still from google). You can save the image as bmp by pressing "Save image", you will find it in the folder of the app, or in the same folder with the source code.
 As long as it is a first version, it will be buggy and it will requires a lot of improvement. The code is free (use with your LabVIEW License).
Don't hesitate to give me your feedback, I will be very glad to hear it!
Comments
Proven Zealot
Proven Zealot
Unfortunately I don't have LV 2018 to play around with this, but it's helper apps like this that are the most awesome.  Smiley Happy
Bill
CLD
(Mid-Level minion.)
Contributors
