I am testing the LIN code sample for the .NET wrapper.
LIN Diagnostic Master VB.NET
The solution has a compilation error when calling the function:
Dim ptr As IntPtr
ptr = Marshal.AllocHGlobal(CInt(4 * allschedsize))
niXNET.PInvoke.nxdb_getProperty(ClstRef, niXNET.xNETConstants.nxPropClst_FrmRefs, allschedsize, ptr)
And it's normal because none of the definitions matches the ptr variable.
<DllImport(niXNETdll, EntryPoint:="nxdbGetProperty", CallingConvention:=CallingConvention.Cdecl)> _
Public Shared Function nxdb_getProperty(DbObjectRef As UInteger, PropertyID As UInteger, PropertySize As UInteger, ByRef PropertyValue As UInteger) As Integer
End Function
Public Shared Function nxdb_getProperty(DbObjectRef As UInteger, PropertyID As UInteger, PropertySize As UInteger, ByVal PropertyValue() As UInteger) As Integer
End Function
Public Shared Function nxdb_getProperty(DbObjectRef As UInteger, PropertyID As UInteger, PropertySize As UInteger, ByRef PropertyValue As Double) As Integer
End Function
Public Shared Function nxdb_getProperty(DbObjectRef As UInteger, PropertyID As UInteger, PropertySize As UInteger, PropertyValue As System.Text.StringBuilder) As Integer
End Function
Has anybody the good conversion working?
I've tried some unsuccessfully...:(
Thank you!
