Example Code
niDCPower Two Channel Measure Record with Triggers
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Overview
This example demonstrates how to configure two channels on a PXIe-4154 to output a signal. A measure record length is defined for each channel based on a trigger or signal source.
Description
This VI is an example that is configured for a PXIe-4154 Battery Simulator using the NI DC-Power 1.5 driver or later. The VI configures 2 channels to output a configurable voltage with a current limit. A measure record is defined for each channel and can begin based on a trigger or immediately after the Source Complete signal is received. The size of that record can be defined by the user. The voltage and current data from each channel is displayed on a corresponding voltage or current plot.
Requirements
  1. LabVIEW 2012 (or compatible)
  2. NI DCPower
  1. Unzip the attached folder to your computer
  2. Open the VI "niDCPower Two Channel Measure Record with Triggers 2012 NIVerified.vi"
  3. Run the program
VI Snippet
Steve B
