Overview
This example demonstrates how to implement a reference trigger on FPGA and stream trigger data to Real-Time application.
Description
Requirements
Software
Hardware
FPGA VI:
Write data into a circular buffer with a subVI generating the write addresses. When the trigger fires the subVI also generates the address for the oldest item in the buffer. Once all the requested samples have been written to the FIFO the FPGA flags to the RT and stops executing. To make this retriggerable simply loop!
We are generating the trigger from RT for testing but this could come from analog values on the channels or another part of the FPGA code.
Real-Time VI:
Hi James
I am trying to develop this myself but I dont know where to start. I dont like the idea of buffering into block memory as i dont want to limit the amount of post-trigger values from the FPGA to the host. I would rather set a predefined pre-trigger buffer length (say 5000 samples) and stream that to the host along with post-trigger samples.
I see that there is a bug in the first screen shot, i.e. the image is not showing the FPGA implementation. are you able to email me the details if you dont mind.
my email address is ronny.veljanovski@live.com.au
Looking forward to your reply.
Ronny
Hi James
Thanks for the quick response. The concept is very streamlined and cool.
I will work on it tomorrow and see if it works once I make some changes to my VI's.
Thanks again
Ronny
From: JamesMcN <web.community@ni.com<mailto:web.community@ni.com>>
Reply-To: "ni-2144636708-170q-2u-bm4@decibel.ni.com<mailto:ni-2144636708-170q-2u-bm4@decibel.ni.com>" <ni-2144636708-170q-2u-bm4@decibel.ni.com<mailto:ni-2144636708-170q-2u-bm4@decibel.ni.com>>
Date: Thu, 10 Mar 2011 21:07:27 +1100
To: Ronny <ronny.veljanovski@crcbid.com.au<mailto:ronny.veljanovski@crcbid.com.au>>
Subject: - Reference Triggers on FPGA (With Data Streaming)
Community<http://decibel.ni.com/content/index.jspa>
modified by JamesMcN<http://decibel.ni.com/content/people/JamesMcN> in NI Developer Community - View the full document<http://decibel.ni.com/content/docs/DOC-15052
I was wondering why you had decided to use a separate block memory for each Analog Input. Is it possible to have one block memory and interleaved data from each into this? Thanks!
