ag34405a v3 improved example
コードとドキュメント
添付
an improved version showing more of LabVIEW's sequence by wiring features and removed two globals.please remind that I could not test the program, Maybe a small wire has escaped......
The difference between the examples is not only optical. By using the existing while loops for constantsand use the local var for "measuring" I could get rid of the sequence frames except the first.Also notice that the variables like append and pathname are not by accident in the last while.In this way the user can operate these until the measurement has finished.succes, and yes thanks Yves for giving me the opportunity to teach.  Change control:
2006 - 11 -23 new version layout changed a lot
greetings from the Netherlands
NIコミュニティのサンプルコード交換のサンプルコードは、MIT Licenseによりライセンス供与されています。
寄稿者
