Example Code
XY Graph Zoom in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
1. Overview:
This VI allows the user perform a zoom over XY Graph. At the same time, it returns the boundaries of the selected area and allows the user print the selected graph and create a CSV with the array values within the selected area
2. Description:
This example allows the user to interactively zoom a part of a XY graph, print the selected area and save the data inside the area in a CSV file. In order to implement this, the state machine design patter is used. After resetting all the values to their default values, the state machines waits for an user interface event (Zoom, Print, Save to CSV or Stop) and handles each event using the event structure. Check array boundaries subVI checks the boundaries of the selected area.
3. Requirements
  • LabVIEW 2012 (or compatible)
4. Steps to Implement or Execute Code
  1. Open XY graph zoom LabVIEW 2012 NI Verified.llb
  2. Open XY graph zoom LV2012 NI Verified.vi
  3. Run the VI
  4. Put the cursor over the graph and select an area to be zoomed
  5. Select Print, Save to csv or Stop
5. Additional Information or References
 VI Front Panel
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
Comments
jjalbiter
Member
Member
on
Excelente aplicación, sobre todo para realizar análisis y procesamiento de señales.
Muchas gracias por el aporte.
hohensteinit
Member
Member
on
Great. That's what I've been looking for. It's very usable. THANKS !
