Example Code
Writing Units and Description to a TDMS File in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
1. Overview:
This example writes a simulated signal to a TDMS file and adds channel information
2. Description:
The TDM data model offers three levels of hierarchy: root, group, and channel. Each level accepts an unlimited number of user-defined attributes, which makes the files search-ready.
This example demonstrates how to write units and/or description to the channel level using the TDMS Set Properties function.
3. Requirements
  • LabVIEW 2012 (or compatible)
4. Steps to Implement or Execute Code
  1. Run Write TDMS with channel properties LabVIEW 2012 NI Verified
  2. Select a place to save your TDMS File
  3. In the TDMS File Viewer select a channel and verify that the "Description" and "Unit_String" properties are present
 5. Additional Information or References
Block Diagram
Chris Van Horn
Comments
yin_the_novice
Member
Member
on
Thanks so much for posting this , it helped me a lot on my project
Jason93
Member
Member
on
chris this looks nice but what if you want to have different  units for each signal. This makes the units the same for all.
jason
