Example Code
Writing String '\' Codes Display to File
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to access the "\" codes display for a string.
Description
Set the Display for the String control you would like the Codes display for and set it to '\' Codes by right-clicking it on the front panel and selecting '\' Codes Display. On the block diagram right click the control and select Create»Property Node»Text»Text.
If you want to write to a file the ASCII representation for un-displayable characters you can use this example.
Requirements
LabVIEW 2012 (or compatible)
1. Write the string you would like to obtain the "\" characters.
2. Run the VI.
Bryan H.
