Example Code
Write and read metadata from PNG using IMAQ
Code and Documents
Overview
This example demonstrates how to add metadata to an image file.
Description
This VI opens an image file and add meta information to the image file or reads meta data out of the image file.
The meta data are defined as Author and Timestamp in the example but can be modified as needed.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
Read and Write Meta Data to image file LV2012 NIVerified.vi - Front Panel.png
Read and Write Meta Data to image file LV2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Rahul B.
