Example Code
Write Units and Descriptions to TDMS File
Code and Documents
Overview
This example shows how to write Units and Descriptions to a TDMS file and uses simulated waveform data to show the TDMS functionality.
Description
This code starts by prompting the user to enter path for the TDMS file. The code then opens a TDMS file, writes the Group and Channel names to the TDMS file, and writes simulated waveform data to the TDMS file. It then writes the Units and Description of the TMDS file using TDMS Set Properties, reads back the TDMS file data, and closes the TDMS file.
Hardware and Software Requirements
LabVIEW NXG 1.0 (or compatible)
1. Run this VI
2. Select a place to save your TDMS File
3. Verify with TDMS Read that the TDMS File Data matches the
simulated data.
Rita Prather
Software Product Manager
rita.prather@ni.com
Contributors
