Overview
This VI takes the front panel's Table control and appends its headers before writing to the measurement file.
Description
Writing a table control to a measurement file results in only writing the table content. By default, the table row and column headers are not included in the file. This VI takes the front panel's Table control and appends its headers before writing to the measurement file. Thus, both the table headers and the raw data can be found in the file.
This VI uses a case structure to write a table control to a measurement file. When the boolean control is set to false (write without headers), a simple Write to Measurement File function uses the table data and writes it to a created Table_Text_File.txt. When the boolean is set to true (write with headers), the table headers are added to the first row and column of the table's array before writing to the file. This is done using the Row Header String and Column Header String property nodes and inserting them into the table array using the Insert into Array function.
Requirements
Additional Information or References VI Block Diagram
VI Block Diagram
