1. Overview:
This VI stores the values in a 1D Array as single elements in multple columns in a TDMS File
2. Description:
When writing to a TDMS file, the TDMS VIs automatically log data grouped in channels according to the rows of a 2-D array. If attempting to write a 1-D array of data representing multiple channels, a conversion is required. This VI takes a 1-D array, builds a single row 2-D array and then transposes it, getting a multiple rows 1 column 2D Array. Then, this array is written in the TDMS file with each element of the original array corresponds to a single data-point in a new channel.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
VI Snippet
Wouldn't this be more memory efficient if you put the 1D array into a single input build array and a transpose 2D array instead of indexing the loop outputs.
Feel free to improve upon it!
This works great but I am having trouble writing this TDMS file out to a spreadsheet. What is the trick ?
