Example Code
Write Front Panel size and location to .ini file Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This vi, when run will write the size and location of another vi's front panel to an initialization file.
Description
This vi, when run, will write the size and location of a particular VI to an initialization file. This initialization file can then be used at the beginning of an application to appropriately size and place a front panel vi during development. Meant to accompany
https://decibel.ni.com/content/docs/DOC-36156
Requirements
  • LabVIEW 2013 (or compatible)
  1. Make sure the .ini file is in the same directory with this VI and with right format.
  2. Fill in the path of the VI in the file path constant on the block diagram
  3. Run the VI.
  4. Check the content of the .ini file.
VI Snippet of Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Applications/Systems/Test
National Instruments | AWR Group
Comments
Jeffrey-yuefeng
NI Employee (retired)
on
if the .ini doesn't exist, the example won't work.
