Example Code
Write Digital Output of 9512 using SoftMotion and LabVIEW
Products and Environment
    Software
  • LabVIEW Softmotion
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to write a digital output line using NI SoftMotion Module.
Description
With this example you can change the value of the digital output using softmotion. The write methode is modified to "write digital line" by right click on the function block.
The digital line 0 represents the DO0.
Requirements
 Software
  • LabVIEW Full Development System 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible)
  • NI SoftMotion Module 2012 (or compatible)
  • NI-CompactRIO 12.0 (or compatible)
 Hardware
  • NI Real-Time cRIO
  • NI-9512
  1. Run the VI.
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
--Michelle
