Overview
This example is a simple VI that performs a word count on a string by counting spaces between words.
Description
This VI uses the match pattern VI to search a string and count the number of spaces, effectively doing a wordcount.
Requirements
VI Block Diagram
Your vi doesn't account for a text string that may contain multiple space between words or words separated by tabs or other punctuation.
A better match pattern string would be "[A-Za-z-]+" which will count actual strings of characters as words including hyphenated words.
you could also then remove the +2 as the loop will run a final iteration where it doesn't find a word which will offset the 0 based iteration count.
Hi, Steve
I'm beginner in labview and I did not understand what is "[A- Za- z -] +" can you explain bettter witch string I have to use for my counter disregard more than one space between words please
thanks,
Carol Vieira
Carol, The match pattern vi treats that as a search string for any combination of the uppercase A-Z and the lowercase a-z and the hyphen character joined together. ie, a word.
The + after the brackets means it will match any number of those successive characters until it hits a character that's not part of that set.
It's not looking for spaces so any number of spaces would not count as a match and therefore be ignored. MHutch's example above counts spaces not words, but if you define a word as a string of alpha characters and perhaps hyphenated then the "[A-Za-z-]+" would search for "words". Perhaps an apostrophe character as well could added to the string within the brackets, but I doubt it would affect the word count.
Thank you very much ![]()
Hi Steve03,
Can you please explain more about how to use special characters in match pattern functions.
Appreciate if you can provide more & more examples for each special characters.
Thanks.
Thank you Steve.
This really help. ![]()
