Overview
This example shows you how to perform events with the mouse such as clicking or scrolling. It uses the Call Library Function Node to reference the API.
Description
This code shows how to perform events with the mouse such as clicking or scrolling. The Call Library Function Node calls a DLL or shared library function directly.
Requirements
- LabVIEW 2012 (or compatible)
- Utilize the attached VI as a subVI.
- Create a control or constant from the terminal and select the desired mouse event.
VI Snippet
Che T.
