This example allows you to both Put and Get files from a WebDAV server/target (like a cRIO 9068).
Description
The example includes two functionality. First, put a file from the local directory onto a network location. Second, get a file from network location and put it on the local hard drive, then check the size of the file.
1. Specify username/password, file URLs and URIs.
2. Run the VI. The VI also specifies the file size.
Thanks for sharing your code! but a little bit of explanation on how the code works would have been nice!
Hi Joel,
Do you have a version of your Webdav Vi that can use a Private Key instead of a Password?
Steve
