Example Code
.Wav sound modifier
Code and Documents
Overview
This VI allows modification of the sound played from a wav file, and outputs the results to speakers.
Description
This VI gives some standard sound modification opions such as bass, treble and midtone. You can also modify the speed of the track playing and the volume on the output. Visualization of the sound can be seen in the form of the wave itself, and 1/3 octave analysis.
Bass, treble and midtone changes are acheived by use of lowpass, bandpass and highpass filters respectively. The speed of the sound is modified by altering the value of dt using the align and resample VI.
There are two versions of this, as the version with the 1/3 octave analysis requires the sound and vibration toolkit.
Included to download is a festive .wav file.
  1. Specify path of .wav file or click run to open file dialog
  2. (Optional) Choose .wav file in file dialog and click okay
  3. Modify dial values to modify sound properties
Requirements
Software
LabVIEW 2010 +
Sound and Vibration toolkit (Optional for 1.3 octave analysis)
Hardware
Speaker / Headphones
Code Snippit
This code snippit is for the version that includes octave analysis
Additional Images or Video
Image of front panel with octave analysis (right)
Image of front panel without octave analysis (Requires sound and vibration toolkit)
Matt H
National Instruments UK
Comments
SLIMLAZY1
Member
Member
on
i love you! #money!
Contributors
