Overview
This example implements a hard decision based Viterbi decoder on an FPGA bitstream file. It retreives decoded bitstream data from the FPGA and pushes data back to the FPGA.
Description
Viterbi decoders are used in systems where data are transmitted and subject to errors before reception. For example, wireless transmissions are prone to error before reception so it is typically seen in applications like digital video, radio, mobile communication, and satellite communication. Specifically, a Viterbi decoder is a method that uses the Viterbi algorithm for decoding bitstream files that have been encoded using an error-correcting code called convolutional code. Convolutional encoding is a forward error correction technique that is useful in applications where the transmitted signal is corrupted by additive white gaussian noise. Additive white gaussian noise appears normally in wireless transmissions.
Convolutional codes are usually described using two parameters:
Viterbi decoding has the advantage of fixed decoding time and is well suited to hardware decoder implementation as seen in this example. But since computational requirements grow exponentially, which causes this to be a resource intense decoding method, it is normally limited in practice to constraint lengths of K <=10.
In addition, convolutional code can be described by generator sequences that are the impulse responses of each coder output branch. Generator sequences specify convolutional code completely by the associated generator matrix.
Hardware Viterbi decoder for basic code usually consists of three major blocks:
In this specific example, this decodes a rate (r) =1/2 convolution code with a constraint length (K) = 7 and programmable generator matrix. The example uses a programmable generator matrix to specify the convolutional code in the FPGA VI and decode the code in the Host VI. It is a hard decision Viterbi decoder.
Requirements
Software:
Hardware:
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
There is no Zip file attached along with.,
Please do upload the Zip file
Hi Kalyan,
You can find the example at ni.com\labs under LabVIEW FPGA RF Communications Library.
This is free for download.
--NI RF Group
Dear NiRF Group,
Thanks a lot for the link
Regards
Kalyansuman
i am writing a my own fpga code .....so i allways connect to fpga target......plese give me a solution ....for developing a my own fpga codes ......
Hi! I've been trying to run this code for ages but the decoded bit always seems to be FALSE. I'm using the Viterbi Decoder [171 133] and trying to run the VI continuously (after resetting and asserting the INPUT VALID input). Please help. I seem to be doing something wrong. Thanks very much!
Please refer to the example attached to this page, regarding how the bits need to be packed and how to use the Viterbi decoder. Hope this helps.
I need to perform 3/4 depuncturing on my stream first and then pass perform viterbi decoding. Can this code accept a depunctured stream? How can I modify it?
