VirtualBench: Master SPI With the DIO
製品と環境
このセクションは、サンプルの作成に使用された製品およびOSを反映します。
以下に示された製品を含め、NIのソフトウェアをダウンロードするには、ni.com/downloadsをご覧ください。
    ハードウェア
  • VirtualBench All-in-One Instrument
コードとドキュメント
添付
Description
Overview
This example automates the digital input output (DIO) channels to master SPI commands and performs a read.
[+] Enlarge Image
Steps to Run Program
    1. Download the example program on the right under downloads.
    2. In LabVIEW software, open the program by going to File » Open… and navigating to the file.
    3. Connect the VirtualBench device.
    4. Select the correct VirtualBench bus channel from the pull-down menu of the VirtualBench Bus Channel control. Set the clock rate, clock polarity, clock phase, and chip select polarity; specify the data to write
    5. Click the Run button to write and read data.
    6. The data acquired will display in the Results indicator.
Program Explained
[+] Enlarge Image
    • Initialize Session
      • The VirtualBench bus channel is passed into the SPI Initialize VI to initialize a new session on the SPI engine for the device.
      • A Boolean true constant is also passed into the VI to reset the device to default values.
    • Configure Instrument
      • Instrument and error information are passed into the SPI Configure Bus VI along with the clock rate, clock polarity, clock phase, and chip select polarity.
    • Perform Operation
      • Instrument and error information are passed to the SPI Write Read VI.
      • The data to write is also passed into the VI, and then the VI performs a write followed by a read.
      • The VI then outputs the data read to the indicator on the front panel.
    • Close Session
      • The instrument and error information are passed to the SPI Close VI. This closes the session and deallocates any resources for the next time a session is created with the instrument.
    • Handle Errors
      • Finally, the error information is passed into the Simple Error Handler VI. If an error has occurred, a dialog box will open to notify the user.
Additional Resources
VirtualBench Examples
NIコミュニティのサンプルコード交換のサンプルコードは、MIT Licenseによりライセンス供与されています。
