Example Code
Verilog Waveform Generator (String Manipulation) using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Convert a LabVIEW digital waveform data type to Verilog code which outputs the same waveform.
Description
When programming FPGAs with Hardware Description Languages (HDLs) such as VHDL and Verilog, a very common task that needs to be performed is the generation of control signals for separate code modules within the FPGA or for external peripheral devices such as Liquid Crystal Displays (LCDs).  Often, the task of ordering and triggering of these control signals in these low-level languages can be pretty arduous, and often results in the programmer consuming a lot of coffee, which can sometimes be unhealthy.
LabVIEW's Front Panels offer the Digital Waveform Graph, a great way to visualize and manipulate digital data. We can use the graph to first prototype our generation signals and then use Property Nodes and String Manipulation to generate the equivalent Verilog code.
The Verilog code produced assumes the incorporation of a Clock Signal (clk) and a Reset Signal (rst). The Clock Signal will need to run at least twice the rate of the maximum frequency of any signal depicted in the Waveform Graph.
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Open “Verilog Waveform Generator 2012 NIVerified.vi”
  2. Notice the waveform saved in the Digital Waveform graph.
  3. Run the VI.
  4. The “Verilog Equivalent” indicator will shows Verilog code corresponding to the waveform in the Digital Waveform graph.
VI Front Panel
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
Comments
PiotrMaj
Member Member
Member
on
Nice, thanks.
PS. the picture made me write the comment.
Alex.T
Active Participant
Active Participant
on
Thanks very much!
