Description:
In this example, you will use Edge Detection and Color Measurement steps to verify that the part under inspection has a black wire on the left and a red wire on the right. You will edit the default Inspection Interface with the Pass/Fail status of only a few specific steps. For this example, you will use the disk that has the electrical connectors with the black and red wires attached to it.
This example instructs you to use a simulated acquisition step instead of acquiring images from a camera. In an actual inspection, a simulated acquisition is not practical and a camera should be used to acquire images of the parts as they are inspected.
Here is a link to download Vision Builder AI 2012 SP1 f2.
This example was used during the Getting Started with NI Vision session at NI Week 2013. The other example is Detect Coins: Vision Builder AI.
Instructions:
