Example Code
VeriStand Stimulus Profile API in LabVIEW
Products and Environment
    Software
  • LabVIEW
  • Veristand
Code and Documents
Overview
The example shows how to use the Stimulus Profile API (non-Legacy) to interact with Real-Time Sequences developed for NI VeriStand. This example is written in LabVIEW 2014 and developed for VeriStand 2014. This example creates and runs a stimulus profile. The stimulus profile reads different CSV files each time it runs and creates separate log file.
Description
This example shows how to use the Stimulus Profile API with Real-Time Sequences. This example includes how to programmatically set the CSV file to read and set the log file name in the same manner of tested CSV file. eg Running "File1.CSV" creats "File1.tdms" log file.
Key sections in the example:
  1. Create a stimulus profile which reads CSV file  (Add_Steps.vi)
  2. Create a stimulus profile which reads CSV file and  log  the results (Log_and_Add_Steps.vi)
  3. Deploy Stimulus Profiles
  4. Repeat 2
  1. Place attached VeriStand project under public documents (C:\Users\Public\Documents\National Instruments\NI VeriStand 2014\Projects\)
  2. Deploy VeriStand project
  3. Run Main.vi inside the LVVIs folder (change Disable Structure to test 1 and 2)
Requirements
Software
VeriStand 2014
LabVIEW 2014
Hardware
none
Reference
VeriStand Stimulus Profile API: Stimulus Profile Sessions in LabVIEW
001.png**This document has been updated to meet the current required format for the NI Code Exchange.**
Comments
Yusuke.T
NI Employee (retired)
on
You can find other examples for NI VeriStand API at
C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\NI Veristand\API\Execution API\
